Can I lap my valves in? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-27-2009, 08:44 PM
gas_guzzler's Avatar
I brought some World 305 heads a while ago that came with all parts but were not assembled. The seats and valves look fine but I was told by someone (who I don't know) that they'd have to be reground since they haven't been kept in order.
Is this true or can I just lap the valves and check they seal properly with machining blue ink?
The heads have only had 2 years or less usage.
Old 12-28-2009, 01:30 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
If they're the original valves, I don't know why you couldn't blue check them to find their home, then hand lap to fine tune the seal. A little time consuming, but there's only 8 of each.
Semper Fi
Old 12-28-2009, 02:35 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I agree- the valves will seat as long as there's no real damage/wear.
Lapping using the fine grade compound should suffice- after a quick lapping on a blued seat/valve, you will see whether or not they're going to seal or not. As for locating the exact hole the valves came from, I never tried this- but might well be worth a try.
After lapping and meticulously cleaning things to rid the parts of the grit, put the heads together (springs and valves) and position them in such a way that you can fill them w/kerosene or some other non water solvent to see that the valves are sealed well. There shouldn't be leakage past the seats.
If as-new condition is important to you, and cost isn't a consideration, take the heads and valves in for a 3-angle valve job. You could consider a 30 degree back-cut on the valves, too. But overall, you could get by w/the lapping idea. Others are sure to disagree w/this- and that's fine. I only can say what has worked for me in the past.
Old 12-28-2009, 08:55 AM
302 Z28's Avatar
I agree, use some machinist blue to confirm the width and position of the seat and if all looks good then hand lap with fine lapping compound.
Vince
Old 12-28-2009, 06:24 PM
Thanks for the help people
best way of adjusting valves SBC ??? Augusto Engine 33 03-22-2011 06:04 AM
Lapping New Valves - Help leejoy Engine 11 11-10-2007 09:56 AM
NASCAR, Unleaded Fuel and Titanium Valves QuenchPiston Engine 18 12-26-2006 09:18 PM
Adjusting Valves and Fuel Pump Install demitristewart Engine 5 08-09-2006 11:10 AM
Worth it to put bigger valves in stock seats??? sizemoremk Engine 3 08-13-2005 01:19 AM
