Can I make a 383 strocker out of a 5.3 ltr - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-24-2007, 05:09 PM
John
I have a 5.3 in my 2000 pickup and Ive been told it is a destroked 5.7, if so, I was wondering if I could go the other way and make a 383 stroker out of it and if so what kind of performance gains would I get. I don't think it is the LS4 as It has the aluminum Vortec heads, but iron block.
Any input greatly appreciated.
Old 01-24-2007, 05:38 PM
Wiki Edits: 31
diffrent engine faimily all togther.
Old 01-24-2007, 06:19 PM
5.3 to 383
a 5.3 can be built to 383 ci. i can't find my specs at the moment but when i do i'll post 'em
Old 01-24-2007, 06:57 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
The 5.3L uses the same stroke as the Gen III 5.7L and the 6.0L at 3.622" The 5.3 has a 3.779" bore, the 5.7L has a 3.893" bore and the 6.0 has a 4.00" bore. Even if you were to take the 4.00" stroke out of the new 7.0L you're only going to end up with a 359" V8. And I don't even know if that crank would even fit. Unless there's an aftermarket crank somewhere with a 4.25+" stroke I highly doubt you're going to stroke your 5.3 out to a 383.
BTW, the GEN III 5.7L shares nothing in common with the older Gen I/II 5.7L/350
Old 01-25-2007, 02:53 PM
John
Is this a kit that you speak of or just an accumulation of parts, either way I would be really interested to know how you did this. If there is a site that you know of were I could see this I appreciate any info you have.
thanx john
Old 01-25-2007, 03:52 PM
techinspector1's Avatar
Wiki Edits: 326
Contact these guys and ask. They've been doing stroker kits since I was a kid (a long time ago)......
http://www.speedomotive.com/StrokerCranks.aspx
Ok, here's the debate of the century: 383 or 400 chevy!! Cast your vote and reason killerformula Engine 303 03-28-2013 08:08 PM
Supercharging and fuel injecting a 383 Chevy Noesis Engine 11 09-21-2007 05:51 AM
383 stroker with AFR heads - never fired. Make me an offer.Need cash fast for project elukas Engine 0 02-06-2004 01:53 PM
mistmatched 383 NAIRB Engine 10 12-01-2003 07:28 AM
How to make a 383 1973ChevroletNova Engine 4 03-16-2003 06:05 AM
