can I put body filler over primer? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2011, 12:11 PM
lamothe1's Avatar
Iím getting my í34 ford frame sandblasted and it will be back in a couple of days. The blasting company said I should get primer on it within 24 hours, but I would like to put some plastic filler on the grinding marks and fill any rust pitted areas as the frame is going to be painted in gloss black and i want it to look perfect. Iím wondering if I can put bondo over the primer or could I do the bodywork first. In the past when Iím fixing a dent on my cars I always grind down to the metal and apply the filler, sand and then primer, but in this case they said I should get it primered Quick. It will be in the garage so I donít think I will see any visual rust for quite some time as I have some other small suspension pieces I sand blasted myself a month ago and havenít got around to priming yet and they still look fine. So my question is: can I put plastic filler over primer?
Old 12-28-2011, 12:23 PM
life is a temporary assignment
I would seal it with some good Epoxy primer first, Then body filler, Then a 2k primer, Then paint..
Old 12-28-2011, 01:56 PM
To answer your question, yes you can put filler over primer as long as you sand it first with 180 or courser grit paper. I do also agree that I would get a good epoxy primer on it first, then you can take your time getting back to it.
Old 12-29-2011, 06:22 AM
You need to be sure to use a sandable epoxy such as SPI or Kirker. The filler will stick to sanded epoxy very well, but if you do it during the recoat window you will get increased adhesion. SPI has a seven day recoat window.
http://southernpolyurethanes.com/Pricing%20Info.htm
Old 12-29-2011, 07:19 AM
I looked at a map, Cypress is about 6 miles northeast of Seal Beach?
You get one foggy day, or a day that is cool or cold by LA standards, and then the weather shifts, and you get a warmer moist breeze from the southwest, and your sandblasted steel will turn orange with rust. You could possibly get away with letting it sit a few days in Summer, provided the weather did not shift, but it is not Summer, now
Sandblasting leaves the metal surface stripped of any thing that will protect it. In fact, it stresses the surface of the metal, making it more likely to rust.
Epoxy it. ASAP!
Old 12-29-2011, 10:18 AM
lamothe1's Avatar
Thanks guys, I got the frame back this morning and i'm going to prime it in the afternoon and then i can take my time doing the bodywork.
Old 12-29-2011, 10:35 AM
You need to clean that good so you are painting on metal instead of sand dust.
Old 12-29-2011, 10:40 AM
The rain is hitting Oregon today, so So Cal should be dry.
Old 12-29-2011, 10:50 AM
Haven't you ever heard that song, "It never rains in southern California"
http://weather.aol.com/forecast/toda...s/id/usca0276#
Old 12-29-2011, 12:04 PM
lamothe1's Avatar
yeh, it's going to be about 78 degrees today.
Old 12-29-2011, 04:27 PM
filler over primer
Its best to prime right away because of oxidation it also ok to put plastic filler over primer
Old 01-03-2012, 06:52 PM
DMJ DMJ is offline
I didn't see anyone mention phosphoric acid to kill surface rust before coating with epoxy, either that or use an etching primer. The phosphoric acid I refer to is caller rust conversion coating. For metal in an enclosed place the rust conversion coating is good enough to not have to prime for a few months.
Old 01-05-2012, 06:07 AM
deadbodyman's Avatar
Wiki Edits: 11
Thats because most guys dont use it properly and have problems and others think ALL acid products are the same (not true) ..blasting is good but blasting and ospho cant be beat...around here you can almost watch a nice clean body rust before your eyes and Ospho is the only way to stop surface rust effectivly ......I'm sure there are other products that work equally well but when you find something thats works as well as this theres no reason to switch...Ospho REMOVES rust but it'll also convert what little residue (if any)is left ,after its dry it'll protect bare metal for years inside and a couple weeks if left outside...I wont strip a car and NOT use it first...What a difference it makes....As the others say a sandable epoxy is the best foundation to start with....
Nason 421-17 primer over body filler? cboy Body - Exterior 3 12-17-2008 04:37 PM
Urethane primer and body filler Lator_Gator Body - Exterior 23 01-08-2007 02:15 PM
Can I put body filler over etching primer wickiewicked240z Body - Exterior 3 08-27-2006 09:40 PM
Body filler over the primer? Skipr Body - Exterior 3 11-22-2005 05:19 AM
Body Filler Over Epoxy primer lowlife_caddy Body - Exterior 4 08-26-2004 04:14 AM
