Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Can I put clearcoat on top of a lacquer paint
Old 06-14-2004, 11:46 AM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Wiki Edits: 21
Color sanding and polishing was invented on lacquer paint. That is how you get a great lacquer finish. If the lacquer is well cured it should take a urethane clear coat just fine, just sand it w/ 400 before the clear. From your question it sounds like you have a fresh lacquer job. Why did you do lacquer instead of BC/CC in the first place?
