-   -   Can I put clearcoat on top of a lacquer paint (http://www.hotrodders.com/forum/can-i-put-clearcoat-top-lacquer-paint-41552.html)
viperACR 06-14-2004 10:50 AM
Can someone tell me if I can put a clearcoat on top of a lacquer paint or must clearcoat go on top of a basecoat only. Any does anyone know if i can also wetsand and polish a lacquer paint. If i can then how long can i wait after a new paint job.
Thanks
willys36@aol.com 06-14-2004 11:46 AM
Color sanding and polishing was invented on lacquer paint. That is how you get a great lacquer finish. If the lacquer is well cured it should take a urethane clear coat just fine, just sand it w/ 400 before the clear. From your question it sounds like you have a fresh lacquer job. Why did you do lacquer instead of BC/CC in the first place?
BarryK 06-14-2004 12:22 PM
Clearing should be done with a lacquer clear.
Urethane clear will go over the lacquer but we know two things about putting urethane clear over lacquer:
1) Its going to come off.
2) We just can't say when, could be first day in sun or 10 years from now or anytime in between but it is going to peel.
viperACR 06-14-2004 01:43 PM
I went with a lacquer paint because I painted my bumper with a spray can paint and i cannot find a casecoate clearcoat very easily in a spray can. The paint came out ok. If I do a good job of wet sanding it might come out better than the factory paont which has orange peel on it. i figured i could not do any worse with orange peel than the factory did. The factory paint shines well but it has orange peel
willys36@aol.com 06-14-2004 03:16 PM
On a small piece like that just color sand it w/ 1500/2000 grit and hand polish it with your favorite brand of polish and glaze and then keep it waxed w/ good carnuba. Will last a long long time.
viperACR 06-15-2004 06:15 PM
Willy can you tell me how long I can wait to put the lacquer clearcoat on top of the lacquer topcoat. I heard that it can be put on at anytime. Another question is can the tocpoat be wetsanded prior to the clearcoat or does the last coat of topcoat have to be unsanded. Thanks
QUOTE]Originally posted by willys36@aol.com
Color sanding and polishing was invented on lacquer paint. That is how you get a great lacquer finish. If the lacquer is well cured it should take a urethane clear coat just fine, just sand it w/ 400 before the clear. From your question it sounds like you have a fresh lacquer job. Why did you do lacquer instead of BC/CC in the first place? [/QUOTE]
willys36@aol.com 06-15-2004 06:20 PM
BarryK would be a better one to ask. I have never shot clear lacquer. It has a tendency to degrade in UV so when I used lacquer I just polished the color coat. Urethane clear is actually UV resistant so is great protection for color coats.
BarryK 06-15-2004 07:16 PM
Rule of thumb is as long as car does not leave both or garage
than clear can be applied anytime.
If the lacquer is a sold color you can sand with 600 before clearing but not metallics.
Its been a long time but if you have not bought the clear yet
PPG High performance was one of the best.
RM (Basf) had a good one -can't remember the name.
Dupont's clear buffed like cement.
The nice thing about lacquer you could do about anything you wanted with the big exception of going to a faster thinner on the next coat. Some people buffed the last coat of color than shot the clear on custom work.
Most of us painters from back than are dead from liver failure because of the lead content.
viperACR 06-17-2004 10:40 PM
Thanks for the response Barry. One last question for you experts. If I use a Lacquer paint does anyone recommend putting a clear on top or does it not make any difference. What has the best shine properties. I know that BC/CC is the best for shine and durability. Any thoughts thanks!
willys36@aol.com 06-18-2004 09:00 AM
Clear coat makes a better looking paint job whether you are using Testors 2oz rattle cans on a model car or top of the line $$$$$$urethanes on your dream rod.
troy-curt 06-18-2004 11:44 AM
Dupont has (or had) a system that used Acrylic enamel clear over lacquer called 502. I've used it and never had any problems.
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
