Can I put a one piece headliner in a 53 chevy pick-up 5 window - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2012, 11:08 AM
Last journal entry: 53 chevy truck
I finally have the pvc foam board up on the inside of the chevy truck 5 window. I was hoping to be able to stretch the leather to cover the whole roof and down past the the corner windows to the belt line.Is it possible to do it in one piece?
If not what is the best way to cover the interior.
Thanks.
steve
Old 10-17-2012, 02:11 PM
DanTwoLakes's Avatar
Wiki Edits: 22
You could if you had a big enough leather hide, but you might still need to tailor the corners. Check out this thread: Custom Headliner for '36 Ford Pickup
Old 10-17-2012, 07:16 PM
I am pretty sure that the hide I have is big enough. I was wondering if I would be able to stretch enough to do the four corners.I though I would do a trial run on the 1/4 inch foam and see what wrinkles come up.
If I have to do some type of pleats or something how should I go about planning this,
Thanks for all help
Steve
Old 10-18-2012, 07:16 AM
Wiki Edits: 22
You have to plan what you want to do outside of the truck and then install it in the truck. You need a way to attach the new headliner board figured out, and be able to take it out to work on it until it is installed permanently. You can't do this all inside the truck.
Old 10-19-2012, 07:00 AM
I am planning to do the headliner like the way Don Taylor does it in his book Custom Auto Interiors. Glueing the headliner to the inside of the truck> I was hoping to get some ideas of were the problem areas will be on this truck.
Does anyone have pictures of what has been done to Advance Design style trucks.
I plan to go to the Good Guys show in Charlotte next weekend, maybe I can get some ideas there.
Please chime folks I NEED HELP.
Steve
Old 10-19-2012, 01:31 PM
Here is one I put in 53 5 window, not sure if it helps.
Old 10-19-2012, 05:17 PM
yea that helps.
I can see splitting the leather where the cardboard ended. Did you use one piece of leather to go around the windows.
That has me thinking?
Thanks
Steve
Old 10-21-2012, 12:15 PM
crsweet91's Avatar
Heres some good shots of a 53 headliner if your still looking for ideas.
1953 Chevy Truck Custom Leather Interior. Interiors by Shannon.com (Upholstery)
1 piece window conversion chevy truck 51 skip99 Body - Exterior 1 01-22-2012 04:25 PM
1948 chevy 5 window pick up bammaboy Engine 1 12-07-2007 12:24 AM
Put that headliner in the dryer?? hotrodf1 Interior 10 04-16-2007 12:48 PM
care to share one piece headliner tips.. anyone?? ddrumguy Interior 4 02-18-2007 04:56 PM
One piece window for chevy truck OperationMidnight Body - Exterior 4 07-27-2005 05:36 PM
