Can i put roadmaster int in 95 caprice
Found sum Buick Roadmaster int, but the only thing is that there power seats and the seats in my caprice arent!!!!!!! Will i still be able to use them
Hi Sean,
I assume your worried about adjusting the seat after it's installed? well before you bolt them in check to see if they work a battery & jumpers, then I'd look to see if there is a factory hook up, I know you said your car doesn't have power seats but it still could be wired for them, if not then I'd wire them through a fuse & new relay. Good luck, Rich |
Like said above you yourself could wire your car for them. The seats themselves house the business that make them move,so all you need to do is run power to them and your all set.
Hi,
What year roadmaster did the seats come from? |
| Recent Interior posts with photos |
| sdlow619 - 70 Impala Fastback & 95 Roadmaster Projects | sdlow619 | Introduce Yourself | 1 | 11-27-2009 04:13 PM |
| can i put headers on a 94 chevy caprice 4.3L | Seanj | Engine | 4 | 09-07-2009 11:10 PM |
| cani put a 350CID,out of 95-00 zz4, in 94 caprice | Seanj | Engine | 5 | 08-25-2009 07:41 PM |
| 95 caprice rear end swap? | molotov 350 | Transmission - Rearend | 2 | 04-08-2007 02:04 AM |
| need help, I want to put a 95 LT1 in a Jeep | postman | Engine | 2 | 06-18-2003 09:39 AM |
