Can I put a turbo 350 in place of 700r4? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-17-2008, 02:26 PM
Hello guys I just bought a 1996 chevy s10 with a 350 vortec and what looks to be a 700r4. As far as I can tell the 700r4 does not have any electronics. I looked underneath the truck and it looks like all the original stock crossmembers and everything else is the same that came with the truck. What I am wondering can I swap this tranny out for a turbo 350 and be able to keep everything else the same with out customizing? Also is the turbo 350 about the same size as the 700r4? I know some may say leave it as it is but I like the turbo cause its cheaper to build and from what I can tell there are a lot more extras for them ready then the 700r4. I can get a brand new turbo350 from summit or jegs for around $700. Well thanks for any help.
Eric
Old 08-17-2008, 03:09 PM
T-bucket23's Avatar
Wiki Edits: 26
You will need to move the cross member as the 700r4 and the 350 are different lengths
Old 08-17-2008, 04:27 PM
Crosley's Avatar
Wiki Edits: 1659
there are 3 different lengths of the t-350 transmission in a 2 wheel drive design.
there is a :
6 inch tail housing,
a 9 inch tail housing
and the 12 inch long tail housing.
The 12 inch tail housing is not real common... the 9 inch tail housing is near identical in length of the 700r4 transmission.
The transmissions from Jegs or Summit are remanufactured units , they are not brand new.
Old 08-17-2008, 06:39 PM
Rubberman2003's Avatar
Yeah like stated the tailshaft is the biggest concern on a truck IMO. My 84z28 came from the factory with a 700r4/ I replaced this with a turbo 350. I just had to get the right length tailshaft, and a adapter bracket to let me use my factory torque arm (which you dont have to worry about). Good luck
Old 08-20-2008, 06:51 AM
+1
I replaced the TH700 in my 91 Caprice with a TH350 and all i had to do was getting the longer tailshaft. I was able to keep the stock crossmember.
Old 08-20-2008, 09:02 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
Something you will need not yet mentioned- is an adapter to change the mechanical speedometer drive on the TH-350, to an electronic pulse generator for the truck.
Old 08-22-2008, 05:44 PM
Thanks guys for the info. I wondered why they did not have a speedometer cable on the truck. I will be getting one from the junk yard and rebuild with a shift kit and performance clutches and stuff. Thanks
Eric
Old 08-23-2008, 01:51 AM
JeffB's Avatar
Eric
Before you go back in time check out www.transmissioncenter.net they have tons of build stuff for your 700R4,the 700R4 has a lower 1st gear which will get you off the line quicker and the loss of the overdrive will cost you 3-4 MPG and at todays gas prices,not a good move plus the cost of the conversion parts and hassle making the swap is a step in the wrong direction.
Turbo 350 & 550 HP BB Chevy leejoy Transmission - Rearend 4 12-06-2007 09:56 PM
350 turbo to 400 turbo swap in lemans?? mtmniles Transmission - Rearend 8 01-24-2006 12:40 AM
Where is the best place to find a 350 engine Andrew7dg Engine 8 10-20-2005 04:28 PM
I have a turbo 350 behind a 350 4bolt main in my 65 Imapala. It shifts into first an shepardb Transmission - Rearend 5 02-19-2004 02:41 AM
swaping a turbo 350 to a 700r4 70camaro Transmission - Rearend 9 02-17-2003 12:51 PM
