CAn I put urethane clearcoat over acrylic enamel - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-15-2010, 10:25 AM
CQNRQY
Excellent Advice!!!
Originally Posted by twjoyce
when buffing flat pieces like the hood, trunk, etc. ALWAYS buff so that the buffer is rotating OFF the edge of the piece. If you let it rotate INTO the edge it will tear it up before you can catch yourself...
You only make that mistake Once
And hopefully never again
Its like grinding always grind off the edge
  #17 (permalink)
Old 01-15-2010, 12:34 PM
To apply urethane clear over harden enamel you must wait 24hrs after application. Other wise the urethane will react with the enamel and you will have a mess. Trust me, been there.
Best method for applying urethane clear over enamel is to wait 72hrs after application then wet sand the finished enamel with 1200-1500 grit. Then apply a mid-coat adhesion promoter followed with 2-3 coats of prepared urethane clear. Then follow manufacturer’s recommendations for buffing.
  #18 (permalink)
Old 01-15-2010, 08:56 PM
Rag top bird's Avatar
Hot rods are still the king
I agree but your time frame may be a little longer with the cold we have had
  #19 (permalink)
Old 01-16-2010, 02:28 PM
mitmaks's Avatar
Last journal entry: Grille
Originally Posted by CQNRQY
Should work Fine
There is a safe window that you can clear over the acrylic enamal with out sanding it . It works great
If your not sure about the time or have exceeded it then sand it with a very fine grit 800 or finer
This omni is great cheap alternative to some of the expensive paints out there! But some colours don't cover as easily but there's always a way around that
exactly. You can tint the primer or put an extra coat or two. I like using sprayout cards to see how many coats it takes to achieve proper coverage.
  #20 (permalink)
Old 02-02-2012, 07:19 PM
everyone has given good advice about the question can i put clearcoat over enamel but i just want 1 person who has tried it to tell me if its alright im useing an oil based paint which i guess is an enamel at least thats what i was told and it already has a shine to it but i would like to apply u-pol clearcoat over my paint because it says its UNIVERSAL and comes with a hardener oh and it is a urethane so the question is still out there can you apply a urethane clear to an enamel/oil base which ever one you want to call it
Enamel vs Urethane vs Polyurethane???? MARTINSR Body - Exterior 11 07-02-2011 06:58 PM
when can I sand Acrylic Enamel? Kawdennis Body - Exterior 2 08-15-2005 04:50 AM
Acrylic enamel question Kawdennis Body - Exterior 11 04-02-2005 09:11 PM
Can I put clearcoat on top of a lacquer paint viperACR Body - Exterior 10 06-18-2004 10:44 AM
acrylic enamel, clearcoat. tactec Body - Exterior 1 09-11-2003 01:44 PM
