Can I repaint - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2011, 10:04 AM
Can I repaint
Just picked up 65 chevelle convertible for good price. The guy I got from painted the car in 2010 nissan red brick last Sept, love the color. Did a great job on body work looks real straight clearcoat laid down great but did not get coverage with the base coat, Looks great in garage but when the car is in the sun it really shows up.He said he completely stripped the car then primed with clausan rust defender then used a black sealer.Should he have used a white sealer with red basecoat? My question is can I just block the car seal it then repaint it. Or do I have to strip the whole car again. Its not going to be a show car ,but want it to look nice I am going to drive it. Thanks for any help. Rich
Old 02-25-2011, 10:10 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
If he completely stripped it, then Yes, you can paint right over it.
Old 02-25-2011, 10:32 AM
repaint
He said he completely striped it. Looking in the door jambs under hood no signs of original paint the guy did a nice job with the prep work,just did not get coverage with basecoat. Its to bad. Thanks again
Old 02-25-2011, 10:45 AM
cyclopsblown34's Avatar
Colorsanding painter
Wash it with Dawn dish liguid til it doesn't bead up and then scrub it with Comet. I'd follow that up with 600 grit wet and then paint.
Old 02-25-2011, 11:26 AM
jcclark's Avatar
The Penny Pincher
Painting over no more than 1 paint job is the general rule,
but there are plenty out there with 3 or more that held up fine.
It all depends on mil thickness and type of paint.
How thick and how flexible.
Thickness can vary a lot, depending on the painter and
materials used.
So over only 1 is usually safe.
After that, I'd strip it to guarantee it.
Old 02-27-2011, 08:39 PM
repaint
Guys thanks for the info, Thats what I am going to do. Let you know how it works out. Rich
Old 03-21-2011, 06:41 PM
mean s15
repaint
I don't spray cars professional or anything but COMET? Isn't that for you know... household cleaning? I'm just thinking of that fine dust that's really hard to get off afterwards. I would prep the car with some prep sol or another good wax remover. Scuff the car shoot the same base color and recoat with clear.
Old 03-21-2011, 07:24 PM
TucsonJay's Avatar
Under reds I use.......... red sealer. Crazy idea huh?
Old 03-21-2011, 07:41 PM
mean s15
Agreed doesn't hurt to mock your color a bit.
Old 03-25-2011, 08:53 PM
mitmaks's Avatar
Last journal entry: Grille
You can add base to white sealer to tint it. If you're painting bright color go with white sealer, darker colors gray sealer and black use black sealer.
Old 03-25-2011, 10:14 PM
The Dawn and Comet do a good job of removing road contaminants on
a vehicle that's been driven between paint jobs.
The leftovers can then be used to clean the bathroom.....
Old 03-27-2011, 06:54 AM
deadbodyman's Avatar
Wiki Edits: 11
Its the grit in the comet that makes it work better than scuffing alone.. you also use a red scuff pad when applying it...its an old,tried and true trick and it works better than scuffing alone...You sand the car first,of coarse ,then bring it outside and wash it with a scuff pad and comet just like you scuff a car..
repaint bruceroberts Body - Exterior 1 04-05-2007 06:14 PM
81 z-28 repaint need help stevej068 Body - Exterior 2 01-22-2007 06:55 PM
repaint fstrthnu Body - Exterior 2 09-12-2006 02:37 PM
Repaint BammBamm777 Hotrodding Basics 1 05-24-2004 09:03 AM
repaint corenele Body - Exterior 5 10-15-2002 08:53 PM
