You can bolt a 4.3 to a 2.8 trans. The 85' S-10 used a T-5. The trans to bell bolt pattern is the same as other GM sticks. A bell from an 80's full size will work. A 4.3 has the same bell pattern as a 305 or 350. Get one with the slave cylinder. Your 85' should have a hydrolic clutch. The pilot part of the input shaft will need cut to make it shorter. Take about half of what is there off. Use a clutch disc from a 5-speed Astro van. It is an 11" disc with a 1"-14 spline hub. You can use a standard 1 piece seal flywheel and 11" pressure plate. You will need a 4.3 S-10 4X4 oil pan and pickup tube to clear the front diff. You need to change the motor mounts. I don't remember if the frame on an 85' has the holes for the mounts or not. There is a bunch there. You might luck out. The radiator has the inlet/outlet fittings on the wrong side. You'll need a 4.3 radiator. None of the brackets off the 2.8 will work either. The S-10 never has a 4.3 with a carb. Your 85' doesn't have anything to run injection. What way you go with that is up to you. When the General put the 4.3 in the S-10 they upgraded alot. They used a NV3500 instead of the T-5. That T-5 is not the same as the one used in Camaros. It's alot weaker. The transfer case was upped to a NV231C from the NV207C you have now. The olny differences between the two was a 1/4" wider chain in the 231, improved oiling in the 231, and they did away with the straight cut gears in low range the makes all the noise in you 207. The 207 is plenty strong to handle a 4.3. Your rear axle is a 7.5" 10 bolt with 26 spline axles. The 4.3's used 28 spline axles. In first gear, low range you will have enough torque to twist an axle. That is if you have enough traction to stop the wheel from spinning. All in all....a bunch of work. As a mater of fact.... The same as if you where going to put a V-8 in. If you do decide on a V-8, find a NV3500 trans to start with. By far a better gear box. Dan
