Originally Posted by Ripped
After less than stellare success, I tried heating the metal with the shrinking disc, then while it was warm/hot I used two dollys to persuade the metal to go where I wanted. It actually worked fairly well.
Thanks for the tips
I have used that process before with great results. Use the disc to warm up the metal then can move that metal around that didnt want to move before.
If you are finding that disc is too big for that area take a small 3in rolec grinding disc and ground that disc smooth on some scrap metal. Then run that disc over the area to be shrunk. Works great on small areas, as ALL you are doing is heating the metal...Eric
