Can I run an Idiot light on a single wire Alternator? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-15-2006, 10:20 AM
RAW's Avatar
RAW RAW is offline
It is now Saturday, everyday!!
Last journal entry: Project '57 Ranchero
I may have screwed up buying an alternator online.
I want my project car to have an original clean looking dash panel ('57 Ford). That includes using the Idiot light to monitor the electrical system. Where I expected to hook up the excitor there is a rubber plug like (I guess) the three wire alternators have (Geez, they really mean a single wire).
How can I connect the Idiot light with the single wire alternator?
Thx in advance, r
Looking for the right '57 Ranchero for a "keeper" this time.
Old 12-15-2006, 10:32 AM
I don't know that I can help you with your dilema, but what I did was purchase a Powermaster XS Volt series alternator. It is a single wire hook-up, but it also has a small micro box on it that can be used for remote voltage sensing, hook-up of a "warning" light, ect...
I was told a normal one wire alternator can't do anything except charge the battery?
-Michael
Old 12-15-2006, 04:16 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
On a Single wire Alternator there is NO Provision for an Idiot lamp.
If you wish to run one I suggest you exchange it for a 3 wire Alternator, Your far better off anyway..you have remote sensing and the lamp provision, plus you don't need the "RPM" bump to start it charging, as you would need with a 3 wire.
A 3 wire is a much better Choice for a street driven Vehicle.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 12-15-2006, 04:21 PM
RAW's Avatar
RAW RAW is offline
I'm afraid it is mine now. Can I convert it by changing out the regulator?
thx, r
Old 12-15-2006, 04:30 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
That would be a question for powermaster...
Doc
Innovations
Old 12-15-2006, 05:14 PM
RAW's Avatar
RAW RAW is offline
Just got an e-mail back from where I purchased the alternator. All I need to do is remove a rubber plug and the single wire will become a three wire. If I had gotten a three wire I could NOT go to a single wire; one way if you know what I mean.
btw, I priced a three wire regulator from NAPA and about $32. That is what I was thinking about with conversion idea. Probably easier to pick a 3-wire and sell off the 1 wire.
thx again, r
Old 12-15-2006, 08:15 PM
T-bucket23's Avatar
Wiki Edits: 26
thx again, r
Actually it will not work totally the same as a 3 wire. In most cases all you need to do is change the voltage regulator to make it a true 3 wire again. You can get these regualtors at any parts store and it will probably cost less than the shipping for a new alternator. It is a very simple change. The only thing you will need to do is hold the brushes back with a paper clip or small nail as described in the previous posts.
if you have the wiring already, i would highly recomend converting it
Chet
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 09:45 AM
Charging system info............... poncho62 Electrical 11 11-26-2005 08:53 PM
1986 Cutlass wiring Q's again :( ChrisMiddleron Electrical 12 07-16-2005 04:22 PM
Idiot light ? Screwy Lewy Electrical 2 07-13-2003 11:31 PM
2 Wire to 1 Wire Alternator bluesman123 Electrical 8 02-04-2003 12:06 AM
