Can I shoot Martin Senior Paint over PPG? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2011, 09:26 AM
I'm asking this question because I am repainting a hood on a 1965 fastback mustang. The car is a gold burnt orange color that is a PPG paint. I am wondering that after I shoot my PPG base on, if I can shoot some Black Martin Senior basecoat over that for stripes. I have to shoot the stripes on, because the whole car already has leman's stripes.
I already have a quart of Martin Senior Black left over from another car. Will these basecoats mix without solvent pop, or a bad chemical reaction??? If I can't mix them, then I'll just go ahead and order some PPG Black. I will also be using PPG clearcoat.
Old 02-18-2011, 09:49 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
As long as you have allowed sufficient flash time before shooting the stripes you should be fine..
Sam
Old 02-18-2011, 10:22 AM
Thanks for the reply! I have another question. PPG makes omni products I believe. I can't get PPG reducer or hardner for my PPG paint, but the store only sells omni. Will i be safe using the Omni reducer, and hardner.
This is becoming difficult, because none of the stores in my area sell PPG. Which is also why I'm seeing if I could use the Martin Senior Black, over the PPG base.
Old 02-18-2011, 10:24 AM
My semi uneducated gut feeling, you are pushing your luck. I would feel a little less leery if you were using a single stage topcoat.
Because it is what I have, I pretty often use PPG DPLF epoxy primer for base coats, and topcoat it with Dupont Centari, with 793s activator.
One option is to spray a test panel. See what happens. Give the test panel a longer period of time to see in any adverse reactions show up.
Old 02-18-2011, 12:12 PM
302 Z28's Avatar
It will more than likely be all right, but I would first do a very light dust for initial application then a little heavier second or third coat. What you do not want to do is lay it on wet right off the bat. Allow more than enough flash time between coats.
Vince
cost to just shoot paint? xpsyclonex2002 Body - Exterior 1 05-31-2010 10:24 PM
Martin Senour Paint Help 1969mustang Body - Exterior 3 02-23-2008 10:15 AM
Using Martin Senour paint (newbie question) thompsy Body - Exterior 3 06-25-2007 12:31 PM
can you just shoot primer then paint? Skipr Body - Exterior 9 05-05-2006 09:02 PM
Question for the paint experts...Barry, Martin... Kevin45 Body - Exterior 11 04-20-2005 08:14 PM
