-   -   can i spray epoxy primer over etching primer without sanding? (http://www.hotrodders.com/forum/can-i-spray-epoxy-primer-over-etching-primer-without-sanding-96886.html)
wickiewicked240z 08-29-2006 08:32 PM
thanks
i found what i was looking for.
roger1 08-29-2006 09:07 PM
Go back and read the advice you were given on your first post.
Take the etching off. Sand the bare metal with 80 grit, then spray on your epoxy.
