Can I swap T-400 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2012, 11:45 PM
Can I swap T-400
Will a th400 be a dimensionally swap for a TH350. mY 35O CRASHED AND i CAN GET A 400 CHEAP.
Old 03-05-2012, 08:46 AM
Supporter of the 4.3 liter V6
400 is longer, and the crossmember may be at a different location than the 350. Vacuum modulator is in a different location on the 400 but thats an easy fix, and the 400 has an electronic kickdown, instead of cable like the 350 so you'll have to wire up a switch to your accelerator pedal.
700r4 to T-400 swap or not? LEROYDOZOIS Transmission - Rearend 1 12-09-2012 05:13 PM
400 sbc swap ?'s TheChevy181818 Engine 2 02-23-2012 07:35 PM
700R4 swap to a T-400 ? JoelHMcCarter Transmission - Rearend 2 06-26-2010 03:49 AM
400 head swap eddiekanjr Engine 0 08-20-2007 03:18 PM
TH 400 swap 409guy Transmission - Rearend 3 05-09-2006 11:17 PM
