can I trade a 350 for a 700-r4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-17-2007, 11:22 PM
want to trade out the thm 350 for a 700-r4 in a 81 silverado 4x4 is that possible?
keeping in mind the 700-r4 is out of a 2 wheel drive
Old 08-17-2007, 11:55 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
I don't know about the 700s but on the TH350 the tailshaft on the 4x4 transmissions are a different length (shorter, I think) than the tailshafts on the 2wd transmissions.
If that's also the case with the 700 then you'd have to pull it apart and replace the tailshaft. On top of that you'll probably have to relocate your transmission crossmember and possibly swap out transfer case adapters. You may also have to shorten your rear driveshaft and lengthen your front driveshaft.
Old 08-18-2007, 11:17 PM
dimension wise the 700 and the 350 are the same size tranny the 700 was designed from the 350 case as matter fact the bottom end of a 350 is just like a 700
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
700 R4 tv cable hook up at carb murrsue Transmission - Rearend 4 10-18-2006 09:50 AM
700 R4 shifting hard jpd37 Transmission - Rearend 8 09-22-2003 03:49 PM
truck 700 R4 computer controlled?? Ridr Transmission - Rearend 2 07-09-2003 04:53 PM
700 r4 vs 400 turbo? WBhunter Transmission - Rearend 3 04-23-2002 08:05 AM
