-   -   Can I Trim This Saginaw Housing? (http://www.hotrodders.com/forum/can-i-trim-saginaw-housing-207249.html)
kimrobertson 10-17-2011 07:50 PM
I have a 4 spd. Saginaw from a 77 Monza with extra casting on the bottom of the tailshaft. I'm putting it in a 79 Nova. The problem is this extra casting gets in the way of the shifter mounting plate that needs to mount up flush with the bottom of the housing. Can I trim part of this housing off? The picture below shows a line I roughly scribed (looks dark) of the small piece that would need to come off the bottom of the housing to make it flat. It looks like it is just extra solid cast iron that could come off.
[IMG] http://img191.imagevenue.com/loc260/..._122_260lo.JPG [/IMG]
cobalt327 10-17-2011 07:55 PM
The photo didn't come through very good but the boss/casting was used for a counterweight that hung off the back of the transmission. It can be removed if need be.
kimrobertson 10-17-2011 08:04 PM
Okay, that's what I thought. Thanks for confirming!
