Can I Trim This Saginaw Housing? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2011, 06:50 PM
I have a 4 spd. Saginaw from a 77 Monza with extra casting on the bottom of the tailshaft. I'm putting it in a 79 Nova. The problem is this extra casting gets in the way of the shifter mounting plate that needs to mount up flush with the bottom of the housing. Can I trim part of this housing off? The picture below shows a line I roughly scribed (looks dark) of the small piece that would need to come off the bottom of the housing to make it flat. It looks like it is just extra solid cast iron that could come off.
[IMG] [/IMG]
Old 10-17-2011, 06:55 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The photo didn't come through very good but the boss/casting was used for a counterweight that hung off the back of the transmission. It can be removed if need be.
Old 10-17-2011, 07:04 PM
Okay, that's what I thought. Thanks for confirming!
Dodge poly bell housing; what manual transmissions fit the bell housing? Hemi-Meadowbrook Transmission - Rearend 2 03-08-2011 08:07 PM
1964 Impala SS Bucket Seat Trim vs 1963 Trim ? 64Joker Interior 1 12-29-2009 08:51 AM
1985 Monte Carlo Windshield trim and rear windshied trim removal ChrisMiddleron Body - Exterior 3 01-14-2005 06:20 AM
Swapping A 3 Spd 72 Gm Saginaw From A P/u To 4 Spd Saginaw From A 68 Camaro GMC72NV Transmission - Rearend 0 11-10-2003 02:51 PM
