-   -   can i use a 4L60E tranny & computer with a carb. engine (http://www.hotrodders.com/forum/can-i-use-4l60e-tranny-computer-carb-engine-9694.html)
r50max 12-13-2002 05:17 PM
I want to put a 4L60E with the original computer behind carburated 350. Anyone know what would be involved in hooking up the computer. IE: throttle position sensor, speed sensor etc.
orangecrush 12-14-2002 06:30 AM
Check with Painless Wiring, they make stand alone wiring systems for this application. My friend did the exact same thing with an older camaro. It is a little on the expensive side, i think he paid around 400 dollars for his harness. I think this is the simplest way, unless you are an electrical engineer.
Seon 12-14-2002 07:44 AM
I was told that a computer from a diesel would work and not as expensive as an after market wiring??
