Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Can I use a 4L80E from a 98 GMC Chevy 3500HD in my 93 Sierra 2500HD??
Old 01-29-2012, 04:05 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Originally Posted by mcampbell02
But they are both the same transmission 4L80E...do you know why?? And if not, do you know which other vehicle would be have the same transmission...if any...my truck is a 1993 GMC Sierra 2500HD 5.7...the VIN states it has the 4L80E transmission in it...I thought maybe there would be another vehicle I could get a transmission out of to replace mine as my reverse is gone.
Thanks again!!
Mary
look at your 4L80e trans... electrical connector on the driver's side for a retaining bolt in the center of the connector. 1998 is a plug / clip on design with no retaining bolt. You would need to update the wire harness connector I am sure
Look at cooler line fittings. 1998 has different location and design of cooler fittings.
Check length on 2 wd transmission. The HD 2wd trucks used a 1 inch longer tail & out put shaft.
