-   -   Can I use a 4L80E from a 98 GMC Chevy 3500HD in my 93 Sierra 2500HD?? (http://www.hotrodders.com/forum/can-i-use-4l80e-98-gmc-chevy-3500hd-my-93-a-213540.html)
mcampbell02 01-29-2012 02:50 PM
Hi there! Just wondering...Can I use a 4L80E from a 98 GMC Chevy 3500HD in my 93 Sierra 2500HD?? I was told only a 1993 would/could be used..but is that only to swap out of another Sierra??
Any help would be appreciated.
Thanks!
Mary
mmerlinn 01-29-2012 03:06 PM
Not without a lot of work and plenty of money.
mcampbell02 01-29-2012 03:52 PM
But they are both the same transmission 4L80E...do you know why?? And if not, do you know which other vehicle would be have the same transmission...if any...my truck is a 1993 GMC Sierra 2500HD 5.7...the VIN states it has the 4L80E transmission in it...I thought maybe there would be another vehicle I could get a transmission out of to replace mine as my reverse is gone.
Thanks again!!
Mary
Crosley 01-29-2012 04:05 PM
Thanks again!!
Mary
look at your 4L80e trans... electrical connector on the driver's side for a retaining bolt in the center of the connector. 1998 is a plug / clip on design with no retaining bolt. You would need to update the wire harness connector I am sure
Look at cooler line fittings. 1998 has different location and design of cooler fittings.
Check length on 2 wd transmission. The HD 2wd trucks used a 1 inch longer tail & out put shaft.
