Can I use a 4L80E from a 98 GMC Chevy 3500HD in my 93 Sierra 2500HD?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2012, 02:50 PM
Hi there! Just wondering...Can I use a 4L80E from a 98 GMC Chevy 3500HD in my 93 Sierra 2500HD?? I was told only a 1993 would/could be used..but is that only to swap out of another Sierra??
Any help would be appreciated.
Thanks!
Mary
Old 01-29-2012, 03:06 PM
Wiki Edits: 85
Not without a lot of work and plenty of money.
Old 01-29-2012, 03:52 PM
But they are both the same transmission 4L80E...do you know why?? And if not, do you know which other vehicle would be have the same transmission...if any...my truck is a 1993 GMC Sierra 2500HD 5.7...the VIN states it has the 4L80E transmission in it...I thought maybe there would be another vehicle I could get a transmission out of to replace mine as my reverse is gone.
Thanks again!!
Mary
Old 01-29-2012, 04:05 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Thanks again!!
Mary
look at your 4L80e trans... electrical connector on the driver's side for a retaining bolt in the center of the connector. 1998 is a plug / clip on design with no retaining bolt. You would need to update the wire harness connector I am sure
Look at cooler line fittings. 1998 has different location and design of cooler fittings.
Check length on 2 wd transmission. The HD 2wd trucks used a 1 inch longer tail & out put shaft.
1937 Chevy School Bus 8.1l/4l80e Build 301247 Hotrodders' Lounge 9 01-04-2012 06:22 PM
Putting a 72' chevy 350 into 1995 chevy silverado that has a 4l80e trans Willbee26 Transmission - Rearend 3 03-28-2010 11:40 PM
cam for 2500HD chas350 Engine 12 10-21-2008 07:32 AM
Replace manual trans with 4L80E - 1999 chevy dually tryc Transmission - Rearend 11 08-23-2008 12:06 PM
Trans Temp, GM 2500HD pickup? xntrik Transmission - Rearend 2 02-11-2007 09:11 PM
