can i use the 700-2-3 Shift Kit with the B&M Shift Improver Kit in my 1985 700r4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-15-2012, 12:07 AM
hi im wanting to know if i can use both kits in my 700r4 im wanting the Manual and the hard shifting also
Old 01-15-2012, 07:05 AM
Last journal entry: update
So, you want to break your 700R-4? Have at it.
I haven't tried the Trans-Go kit, but the B&M kit will do what you want, until the trans inevitably lets go. Not because there's anything wrong with the B&M kit, but because those kits need to be combined with a fresh performance build. Not just a fresh stock rebuild. The 700R-4 can be great, but it doesn't start out great, even with either of those kits.
They were designed to stand alone. The B&M kit has the advantage of raising the line pressure. This does add stress, but it also adds a little holding power, and effectively raises the RPM of the part-throttle upshifts. Not good for MPG, but good for performance. Use the street/strip setting, you'll have plenty of manual control. Everytime it upshifts into second at full throttle, it'll break the rear tires loose, making a bit of sound. This can break U-joints, then you kill a bus load of little kids. And it will kill the band, so expect to gradually lose that tire-noise going into second. It can even break the shell off it's splines, then you're going nowhere fast.
You really need at least a TH400 with a custom driveshaft featuring serious U-joints, or swap in a manual transmission, again, with a custom driveshaft with serious u-joints.
Old 01-15-2012, 07:06 AM
tnsmith10's Avatar
when will it rain???
why would you want to do that? combining 2 different kits is problematic at best as if something doesnt work right, then you spend a lot of time trying to figure out what went wrong.
if you have shifting issues with a current trans and youre just wanting to fix it with a shift improver kit and the trans has got a lot of miles, odds are that youre only giving it a band aid for a deeper problem.
as far as the 700 2-3 kit, again, same thing, and youre asking for trouble.
if this is a fresh build, in order to help you determine what shifting enhancements would work best for what youre wanting out of the trans an idea on what the vehicle is going to be used for would really help. is it a street car only? is it a street/strip car?
you can make the trans shift harder with other means without going with a kit that can potentially cause damage if your not careful. I.E. the 700 2-3 kit will allow any gear at any speed, and not something i would recommend for a primarily street application.
transgo and other manufacturers have several kits to cater what you are looking for shifting wise and as far as manual shifting goes, you can already do that within safety reasons now without the need of a kit.
Old 01-15-2012, 09:37 AM
Crosley's Avatar
Wiki Edits: 1659
why? both kits are not needed for the results you seem to want
Old 01-15-2012, 12:27 PM
thanks to all that replyed i just rebuilt the transmission with the delux kit from monstern transmission and i got the beast sunshell as well but i wanted the really hard shift that bark the tires but i dont want to have porbs with the transmission
Old 01-15-2012, 05:29 PM
joshp83's Avatar
owner of Prices Garage
disd u use a vette servo the trans go kit with a vette servo should bark 2ndf on a freash tranny instead of buyn a band m kit take the 1-2 accumlator use nuts to bring the piston flush with the top of the housing but it will hit 2nd hard all the time un less u have a hp wide band it will damage it is the tv cable set correctly
Old 01-15-2012, 08:43 PM
i used the vett servo and the 500 boost valve.will the the mod with the nuts in the 1 2 acumleter hurt the transmission?
Old 01-16-2012, 12:21 AM
joshp83's Avatar
with a stock band it will break the anchor but a wide band has a wider anchor it will shift very hard ir its a 4x4 that will ad stress to drive train if its 2wd and got a wide band youll be okj with using the nuts on it
Old 01-16-2012, 11:05 AM
nope mine does not have a bigger band that i know oiff
1985 astro 700r4 shift problems smit Transmission - Rearend 7 02-20-2009 07:20 PM
B&M shift improver kit eatonde Transmission - Rearend 6 08-06-2008 11:57 AM
B&M Shift Improver King Kong Engine 2 07-08-2008 05:51 PM
b&m Shift improver kit need help th350 onebad98z Transmission - Rearend 3 04-20-2005 07:16 PM
shift improver 74huggerorange Transmission - Rearend 0 02-18-2003 07:06 AM
