Can I use a Autolight 4100 to replace a Motorcraft 4300 carb..... - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2006, 09:15 PM
onebadmerc's Avatar
I need a bucket of arc sparks
A question for some Ford experts, can I replace the Motorcraft 4300 four barrel carb on my 77 Ford 460 with a Autolight 4100 four barrel carb. Both carbs are rated at 600 cfm. The 460 is out of a 77 Lincoln Mark V and will reside in my 78 F250 four speed manual trans Camper Special pickup. I have heard the Motorcraft 4300 is a fire trap waiting to happen, plus it is in need of a rebuild. I also have a Autolight 4100 four barrel carb for manual trans car or truck, but it too needs rebuilt. Will the Autolight 4100 work on my 460 or will it not?????
Old 07-21-2006, 10:28 PM
aka Duke of URL
Well...
If the engine is from a LINC, the carb is a 4350 spreadbore. The 4100 carb will work but not on the present EGR spacer. You will need a TRANS-DAPT PN 2199 adaptor or try to find a pre-EGR intake (pre-1973) with a squarebore carb pad (you might even find a used EDELBROCK cheap).
BTW- The 4350 is junk. It and the earlier 4300A and 4300D were designed by ROCHESTER for FORD.
TBI from a Chevy to replace a carb on a "Not Chevy" engine Stickman Engine 10 10-27-2004 07:45 PM
Can I replace two barrel carb with four barrel on chevy 305 maverick19642001 Engine 6 02-20-2004 10:00 AM
Edelbrock Carb Chadman Engine 17 12-09-2003 01:10 PM
Mustang V-6 motorcraft 2150 carb. vacuum routing? 87442lover Engine 1 04-24-2003 10:51 AM
Motorcraft 2 barrel carb Levi Engine 4 12-01-2002 12:43 PM
