can i use this kit in my 50 plymouth - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2009, 11:13 AM
somebody please tell me i can use this kit in my 50 plymouth 4dr special deluxe with no problem! i will be swapping in the 11" booster into the kit though if possible.
http://www.piratejack.net/Power-Brak...t-bracket.html
http://www.piratejack.net/High-Perfo...eight-DBK.html
the ladies that run this business are awesome. i hope i can use this kit with the 11" booster swapped in. they gave me a great price.
thanks!
Old 06-23-2009, 12:59 PM
Last journal entry: 50 Ply wagon
Are you changing the motor out to a V-8? If so, you will have valve cover clearance problems with an 11" booster. I have a 50 plymouth wagon and the guy I bought it from had an 8" booster and when I put the 360 in I had very little room between valve cover and booster. I got a 7" dual diaphram and solved the problem.
Old 06-23-2009, 01:18 PM
OMG! you are the guy i need to get to know! thanks for replying so quickly! im going to put a big block in the car...can you tell me if i will have any other issues and what they might be? i know this leaves the post a little so if you need to pm me or something that would be awesome!
im assuming that since you have a big car and a big engine that the 7" must be more than adequate to help you stop??? have you had the car out on the road and liked the pressure/power of the breaks???
also...do you know if the rest of the parts in the set up will work or not??? thanks for everything...your information is going to be very helpful!
Old 06-23-2009, 09:29 PM
48ChryslerRodder's Avatar
Stuck in the past.
the kit will not work on your 50. You have king pin spindles and it will not mount. I have posted in a previous string several links that should provide some good leads on what you have and what you can do to upgrade your brakes.
drum to disc conversion
Hope this helps.
Old 06-24-2009, 07:16 AM
thanks!
thanks for your response. i had read that post of yours and checked out those links...i was just hoping i could use this company because they take such good care of me.
thanks again...until next time...im doing a complete resto of the car...each nut, bolt, washwer, and part will be touched! it should teach me a lot.
Looking for somebody with SSBC disc kit on a 1966 chevy II Mad_Max Suspension - Brakes - Steering 3 03-06-2006 05:29 PM
Build a kit car Dutchman General Rodding Tech 9 09-23-2005 04:39 PM
which is the best overhaul kit 403pontiac Transmission - Rearend 2 05-25-2005 07:50 AM
upholstery kit 39 Ply. 1939P7 Interior 1 11-10-2004 08:31 AM
Brake lines for conversion kit??? ChevyLuv Suspension - Brakes - Steering 9 09-26-2002 08:36 AM
