Can I use the same pads? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2006, 11:29 AM
Malibucdl's Avatar
Laissez les bons temps rouler
Last journal entry: Frame Removal
This is for my DD, a 2001 Chevy Malibu LS. I don't know what Chevy was thinking when they designed the brakes for these cars. I currently have on the car a set of Brembo rotors that have already been turned and they are beginning to warp. I can feel the vibration and pulsing when applying the brakes. Now the pads are in really good condition. I have another set of brand new slotted rotors(got a really great deal on them) sitting in the garage that I want to put on the car. My question is, can I use the pads that are on the car now with the new rotors?
I know it is highly recommended that I use new pads, but I just hate throwing away these pads with so much meat still on them, that and the budget is a little tight right now.
What are your thoughts?
Thanks,
Chris
Old 08-03-2006, 06:39 PM
Malibucdl's Avatar
Anyone?
Chris
Old 08-03-2006, 07:09 PM
poncho62's Avatar
Wiki Edits: 5
Put new pads on and save those used ones for your next brake job and hope you dont need new rotors at that time........................Chances are, with the crap that they put out today, that you till need them though.
Old 08-03-2006, 09:15 PM
Wiki Edits: 31
full metallic pads I'm guessing? if so, get new 1's. the full metallic pads are so hard that they destroy rotors. if they are organic/ semimetallic, you could reuse them, as long as there not cracked or chipped.
Old 08-04-2006, 08:40 PM
Malibucdl's Avatar
The existing pads are Performance Friction Carbon Metalic. So I'm guessing that they would eat up the new rotors?
Chris
Old 08-04-2006, 08:45 PM
Wiki Edits: 31
Chris
yep, they are far too agressive. chuck them and replace with semi metallic.
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 07:17 AM
Metallic Pads (Brakes) dartshadow1 Suspension - Brakes - Steering 6 05-25-2004 07:18 AM
Should new brake pads rub slightly on new rotors firewood Suspension - Brakes - Steering 4 11-25-2003 10:16 PM
Help!! Changing disc pads olds37dude Suspension - Brakes - Steering 9 10-27-2003 11:53 AM
Leaf Spring Pads, are they really needed? OilPatch197 Suspension - Brakes - Steering 1 04-13-2003 10:42 PM
