Can I use a truck proportion value and my car. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-04-2011, 12:25 PM
oldtimercarnut's Avatar
Hi everyone, Happy Fourth !!!!!
I have 1969 disc brakes on my 1967 camaro. They were on the car when I started the restoration an I do not know if they worked then. Now that I am ready for the road I have been trying to get the brakes to work an having no luck. I bought a new Delco master cylinder for disc/drum and took off the small round proportion valve and also the block with the lines and switch in it. I used a 1980 proportion valve off a 3/4 ton GMC truck. I wanted to have everything in one place like a combination valve would do. But when I pump the brake it will build up but if I let the pressure off the peddle it goes back to no brakes, peddle to the floor. I bench bled the master cyl. I bled the lines on the car many times, checked for leaks and have found none. Could it be that I can't use the valve off the truck? The brakes are manual an not power. Any advice would be great. Thanks
Old 07-04-2011, 01:09 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
The information in the link may help you.
Rich
http://www.inlinetube.com/pro_valves.htm
Old 07-04-2011, 06:37 PM
Thanks Rich
I have all the parts that were on the brakes when I got the car. The 1967-70 valves could comprise of as many as three pieces and I wanted to get away from that with a one piece combination valve from 1971 to about the middle 80's. I guess using a truck combination valve will not work. That is the only thing that could be the cause of peddle pressure loss. I will change the combination valve and hope it works. Chuck
72 truck body on a 81 truck frame jeremy1346 Engine 1 10-05-2009 05:07 PM
proportion valve 57chev Suspension - Brakes - Steering 4 08-30-2007 08:13 PM
Making a short bed truck out of a long bed truck suggestions lon77 General Rodding Tech 8 11-22-2006 06:36 PM
brake proportion valves Mr. Wormy Suspension - Brakes - Steering 6 10-08-2006 11:47 AM
brake proportion valves hotrod389 Suspension - Brakes - Steering 2 04-19-2006 11:45 AM
