Can I uses BBC springs with my SBC in my el camino - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-07-2009, 08:49 PM
I put new springs in my 68 el camino. when i drive it, it is not very rigid. The springs are new as are the shocks but the shocks are generic. should i replace the shocks? then see if that helps?
or can i swap out the fronts with bbc springs? has anyone done this? if so what was the result?
thanks
Dustin
Old 10-08-2009, 09:31 AM
spring
Does the car have a sway bar? Try gas shocks I used the white Kyb shocks on my 1967 El Camino with heavy duty or a/c springs,almost to stiff.
Old 10-08-2009, 11:42 AM
1 inch bar in the rear
1 1/4 in the front
my shocks are white....do yours say kyb on them? what are ac springs?
I have heavy duty's in the rear.
Help with my Brake conversion 1968 El Camino pittbull7934 Suspension - Brakes - Steering 0 08-04-2009 01:22 PM
Eibach springs 85 el camino 85elco Suspension - Brakes - Steering 1 01-17-2009 04:56 AM
el camino drop spindles 1979 Camino Suspension - Brakes - Steering 5 08-31-2008 05:04 PM
el camino fenders amish Body - Exterior 1 05-16-2003 04:31 PM
El Camino Song matt37015 Hotrodders' Lounge 4 01-14-2003 04:18 PM
