Can an injector be to large? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-14-2011, 05:53 PM
The mobile view is crap
Can a fuel injector be to large? Is there a formula for what size of injectors to choose?
Old 02-14-2011, 06:23 PM
SSedan64's Avatar
Some Info here about Mid page>> http://www.gnttype.org/techarea/fuel.../fuelpage.html
Old 02-14-2011, 06:28 PM
Go here:
http://www.gtsparkplugs.com/InjectorSizeCalc.html
Keep in mind if this for TBI rather than TPI the fuel pressure will be much lower, on the order of 12 to 14 PSI, not the 43 they are talking about which is a property of TPI type systems with an injector for every cylinder rather than 2 to 4 of TBI for the whole engine.
Too small is the bigger problem as this results with the injector being switched on too much of the time. That burns out the electric coil that operates the injection valve.
Bogie
bad injector? Blob Engine 13 09-26-2011 08:59 AM
Injector # 5 HOT650 Engine 7 10-31-2007 08:57 PM
Injector help. studebaker2jz Engine 0 11-05-2006 01:59 PM
4.3 TBI injector on 5.7 TB?? cknox88 Engine 3 07-29-2005 10:08 PM
injector size segge Engine 2 03-19-2005 10:46 AM
