Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Can Missing a Shift Cause a Rear Seal to go Bad???
Old 04-23-2003, 04:41 PM
adtkart adtkart is offline
I don't know if you took it to a trans shop or not, but if not, they probably didn't have the right tool to install the rear bushing. Most shops won't have a bushing driver that is long enough to install that bushing without messing it up. They will tell you, that they changed it when they did not. Unfortunately, experience tells me, that if the bushing needed replaced and the trans is orginial as well as the yoke, the yoke is likely worn too.
