Can Moly grease be mixed with grease in MOOG ball joints? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-30-2013, 02:38 PM
adam83's Avatar
I've installed my new steering linkage and suspension using Moog ball joints, tie rod ends and idler arm. They have no plastic in them. I have a good Schaeffer grease (#274 Moly EP Synthetic Plus Grease.) The grease in the moog parts is blue, I dont know what type. Can I pump the moly synthetic into my moog parts?
Old 06-30-2013, 03:14 PM
grease/ball jouits
i wouldnt see a problem using any good quality grease.
Old 06-30-2013, 05:12 PM
Banned
x2 pump it in till you see yours coming out. Should be just fine.
Old 07-01-2013, 09:25 PM
I don't see why you couldn't mix those greases. It's not like that joint is going to see high speed friction or heat stress that would make differing greases start separating, waxing up, etc.
Adding grease to upper ball joint tomkeechi Suspension - Brakes - Steering 8 12-06-2012 11:10 AM
What grease should I use on these new bushings and ball joints? adam83 Suspension - Brakes - Steering 9 02-14-2011 04:56 PM
grease or what ? burnt olds General Rodding Tech 1 07-11-2010 10:27 PM
Moly grease for cam break-in? v8hed Engine 12 06-26-2008 06:50 PM
Just a little elbow grease. Rubberman2003 Hotrodders' Lounge 2 12-03-2003 05:51 PM
