Can my pitman arm come out and play? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2012, 11:48 AM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
So I removed the my pitman arm and I notice the tapered stud (that connects to the center link), has *some* play in it. Not much play, but I am sure it will be amplified once it is all assembled. I see what looks like to be some plastic bushings in there. I assume these are the wear points. Is any amount of play here acceptable?
I also notice The stud freely rotates, which makes me think that trying to install the nut on there is going to be impossible. Is this normal?
This is from an '81 Chevy C-10 truck. Now that I know what I know, I should have checked for play before removing the pitman. DOH!
pitman arm ?? tinman386 Suspension - Brakes - Steering 5 05-01-2010 08:03 PM
Pitman Arm for3300 Suspension - Brakes - Steering 3 03-19-2010 10:25 PM
Pitman arm! D-FUNK23 Suspension - Brakes - Steering 9 10-09-2009 10:24 PM
Pitman arm namdlo Suspension - Brakes - Steering 2 11-13-2004 06:02 PM
bad pitman arm? 69elcaminoss Suspension - Brakes - Steering 8 03-02-2004 01:44 PM
