Can the newer Vortec pistons and rods be used in an older block? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2008, 04:45 PM
Twistedwrench's Avatar
No officer I wonít do it again
This may have been asked before or at least covered but I wasnít able to find a defiant answer in searching.
Does anyone know if the pistons and rods from a 98 5.7 Vortec mill be used in an older 350 block?
I have a set from a Vortec and I need a set for an older block both are standard bore yet. Can I just use them or is this a no go?
Thank you
Old 02-13-2008, 05:45 PM
Thank you
They should fit in a good standard bore block. But I would weigh the piston and rad against the old ones to make sure the weights are close.
Old 02-13-2008, 06:27 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Yep, pistons, rods, rings, pins, and some bearings interchange between early SBC, late SBC, and even LT1
Old 02-13-2008, 08:34 PM
Great, thanks guys. I was hoping that was the case. Didnít want to spend much on this block and use what I have lying around. Appreciate it!!
Old 02-13-2008, 08:38 PM
curtis73's Avatar
Wiki Edits: 16
I should add that vortec and LT1 heads are shaped differently than traditional SBC heads, so if you're going with anything but flattops you might want to be careful in the shape of the dish or dome.
Is it possible to stroke a 400 more than it already is? stonedchihuahua Hotrodding Basics 18 11-10-2012 09:27 AM
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
350 Build.. Im sure there are plenty of threads on this... but this is specific!! artillerystevens Engine 10 12-04-2006 10:34 PM
Problems with rods on chev. small block Larry Wilcox Engine 3 01-09-2003 06:13 PM
Forged Rods and Pistons for Ford 302? Mustang 69 Chile Engine 6 10-21-2002 07:39 PM
