Can oil pressure gauge be used for fuel pressure? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2006, 06:54 AM
Arrowhead's Avatar
EFI Rules and Carbs Drool
Last wiki edit: The FREE T Bucket plans
Last journal entry: Sold Everything for a new project
Wiki Edits: 5
For an EFI setup, the fuel pressure is 35+psi, so why can't I use an oil pressure sending unit and gauge so I can have a fuel pressure gauge on my dash. I'm sure someone must make an electric gauge, but Autometer doesn't make one to match my gauge set I already have. I'll still mount a mechanical one on the fuel block, but you can't see that while driving.
Old 02-01-2006, 07:51 AM
You can't run fuel inside the car, you need a fuel pressure gauge setup with an isolator between the outside wall of the firewall and the inside.
Old 02-01-2006, 08:11 AM
engineczar's Avatar
Ditto on what Rick say's, just not a safe idea plus if it's got just the plastic line it may not be resistant to gasoline.
Old 02-01-2006, 09:12 AM
What if it was an electric oil pressure guage?
...just wondering never thought of this before, might be a cheaper alternative to buying high priced fuel pressure guages...
Old 02-01-2006, 09:29 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
Right. My understanding of arrowhead's question was could he use an electric oil pressure gauge, not mechanical. Just out a T in the line and install the sending unit. I'm not sure the sending unit seals are fuel resistant, though they should be.
Old 02-01-2006, 10:22 AM
Arrowhead's Avatar
Wiki Edits: 5
sorry for not making myself clear (I thought I had it covered when I said "sending unit"). but yes, it would be an electric setup with the sending unit by the motor. Sounds like it's worth a try. Thanks
Old 02-01-2006, 10:49 AM
Let us know if it works...I seen some electric oil pressure guages for like 40 bucks with sending unit!
Old 05-01-2008, 07:33 PM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
did someone ever tried this?
Augusto.
Old 05-01-2008, 08:52 PM
did someone ever tried this? ...a fuel pressure gauge on my dash
READ MY LIPS
I think the guy that tried it got into a small wreck, but because he had fuel inside the car, during that small wreck he suffered grave injuries.
Hence...
Old 05-01-2008, 09:13 PM
Augusto's Avatar
seems like very few people understood this post.
ELECTRIC OIL PRESSURE SENDERS stay on the motor bay and only send an electrical signal inside the cab, to the electric gauge, hence no fuel gets inside the cab.
C'mon is that hard to comprehend?
Augusto.
Old 05-01-2008, 09:21 PM
Holder350's Avatar
Auto Parts Professional
should work fine.......and this is a great idea!
I'v seen some oil pressure sending units used for air tanks on air bagged trucks but had never thought of using this tech for fuel.
Old 05-01-2008, 09:29 PM
Augusto's Avatar
great!! finally someone who got it.
but, has it been tried by someone?
how accurate are them oil pressure units?
aren't them too high scaled for carbs? for EFI they may be better.
anyone knows of a brand name that makes them? OEM units will have to be heavily modified for custom usage.
I just thought of dakota digital, it would be nice having a digital readout of the fuel pressure wouldn't it?
Augusto.
Old 05-01-2008, 10:46 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
I hook up a pressure transducer, run the cable into the vehicle, plug in my lab scope and go for a test drive a lot. It would be great to have a permanently mounted gauge in vehicles for fuel pressure testing, and tuning.
Old 05-02-2008, 01:33 AM
Augusto.
i am using an oil pressure sending unit from Summit, digital for FUEL, cost with sender about $45 and replacement sending units are about $15 this total cost is what some guages get for the sending unit alone. The only catch is that I am using it on my DIESEL
ED I do have a mechanical back up.
Old 05-02-2008, 05:44 AM
Arrowhead's Avatar
Wiki Edits: 5
Stroke,
You REALLY need to read posts before going off half cocked.
Thanks for the stern warning though, you might have saved some other unsuspecting soul form doing something stupid
Actually, I never did try this, but it sounds like the general consensus is it would work.
Oil Pressure questions RObs71Nova Engine 22 05-02-2009 01:45 AM
no oil pressure nettio Engine 2 01-24-2006 06:02 PM
oil pressure! motor new, start up 75 lbs ! now1lbs at1400 rpm wantafastpass Hotrodding Basics 6 02-29-2004 11:54 AM
low oil pressure, but no bad engine noise Ledslnger General Rodding Tech 15 11-30-2003 09:30 AM
Low oil pressure fred56 Engine 4 10-08-2003 02:19 PM
