Can Olds distributor go in Chevy engine? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-10-2004, 05:50 PM
70's Olds distributor turns in opposite direction then Chevy distributor. Will distributor from 69 350 Olds engine fit into 76 305 chevy ?
Old 12-10-2004, 09:11 PM
milner's Avatar
olds engines are completely differant than chevy, they will not work. should be real easy to find a dist for a sbc.
Old 12-20-2004, 09:47 PM
NO
the reason why the disturbtor will not work is because if you look at the bottom of the dist on bot of the gear on the u will see a hex head and on a chevy there isn't a hex head it is a tongue insert. Now you take that gear off and put a chevy one in yes it will work.and if it is hei the wire MIGHT be different i don't know.
Old 12-20-2004, 10:28 PM
stepside454's Avatar
isnt an Olds distributer alot shorter than Chev also ?
Old 12-21-2004, 09:27 PM
milner's Avatar
a olds dist is alot shorter than a chevy, and no it will not work.
