can paint get old? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-22-2005, 07:52 PM
can paint get old?
I picked up a gallon of dupont nason full urethane 400 series, it is likely a few years old, it needs to have activator added, I have that fresh. If the base has not frozen, has not settled all to the bottom, should I use it. I had plannned to use it as a first coat to save some on cost of the full urethane top coat I will be using. Is my cheapness going to get me in trouble? It is a very simmilar color. I opened the can and it looks fine. Bottom line...what is the self life of dupont nason fullthane base? thanks
Old 12-22-2005, 08:12 PM
i recently used some dupont centari that i bought about 10 years ago...i took it to home depot had them shake it for me....no problems for me
Old 12-23-2005, 04:04 AM
BarryK's Avatar
Your in fine shape as two years old is not that old at all.
With your paint about the only thing that could go wrong from setting would be a pigment separation and either would be very unlikely unless there was a bad pigment to Begin with.
Old 12-23-2005, 07:52 AM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
Be sure to have it shaken WELL or at the least,use a drill & whip it up good.
Why are you shooting 2 different paint's/coats BTW?
Old 12-23-2005, 08:10 AM
I just shot some Dupont ChromaOne that i had mixed in '95. No problems.Just stir it well.
"Basic of Basics" Can I use "rattle can" paint on my car? Centerline Body - Exterior 33 07-08-2011 12:33 PM
Need advice on a paint job tishmomo Body - Exterior 36 01-15-2008 11:19 AM
Painting roof tips needed..... Bluepen Body - Exterior 7 09-10-2005 09:26 PM
This is interesting. Temporary peel off paint. kenseth17 Body - Exterior 5 08-11-2005 09:41 PM
