Can peanut port heads make power up to 5500rpm? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-10-2010, 08:45 PM
I have read that these heads don't make power above 4,500rpm. Riding in my friends stock dually seemed to confirm this. My question is will these heads in stock form pull to 5,500rpm with 9:75 compression, Isky 264 mega cam, 1 3/4 tri-y hedders, weiand dual plane intake with 800 cfm Q-Jet? I know the large ovals flow better, but i have a set of peanut ports that were freshly done with springs to match this cam, also this engine would be in a 5,000lb+ truck. Thanks in advance.
Old 11-11-2010, 01:20 AM
327NUT's Avatar
If you're not looking for max hp then go ahead and use them. You could have done a little port and polish job and milled the heads a little to up the compression but prob. too late now. Port velosity will be good for the rpm range you are looking at. Don't expect too much but up 5000 rpm it should be ok. Make sure the q-jet is dialed in real good to maximize your combo.
The 80's - 90's 454's were pigs due to very low factory compression and matching inert cam profiles. I had an '88 that chassis dyno'd at 190 hp @ the rear wheels and the dyno operator said that he was impressed.......go figure.
Old 11-11-2010, 08:06 AM
Thanks, im not too concerned with top end power but would like it to pull to 5,000-5,500rpm with about 400hp. Just want a broad strong torque curve. Thanks for the reply.
Old 11-11-2010, 08:22 AM
airboat's Avatar
They used them for 330HP boat engines. 5000-5500 RPM is possible since you have the required valve springs.. Might not be super strong up there however still fun for a truck! Ran my inboard boat up to 5500 however the replacement L29 Vortec 7400 heads sure made a difference. I assume you don't have flat tops if you expect 9.75/1 compression with 118cc Peanuts. Polish the combustion chambers, with that compression ratio it will help reduce chance of detonation if your towing or hauling heavy loads and porting the intake bowl will help.
The problem I have herd with the small intake ports at high rpm is the fuel can return to a non vaporized state when going around the corners.
Old 11-11-2010, 08:47 AM
Yeah the pistons im using are L2349F30-8. Most of my driving won't be near 5,500rpm. But would like it to pull hard up to that rpm for the times that i need it too. These heads seem great for low rpm power, they stopped making power at 4,500 rpm in my friends dually but up to that point the engine felt pretty strong.
Why spend money on heads? F-1Rodder Engine 8 03-07-2008 12:09 AM
Will an oval port intake work with round ( peanut ) port heads? quintorca Engine 6 02-14-2008 11:43 AM
Oval vs. Square Port Heads? Coleman396 Engine 9 07-22-2004 05:07 PM
how much power will this engine make? CombatWombat Engine 13 01-13-2003 10:25 PM
How much power will these heads make? jeff of nc Engine 2 11-17-2002 08:10 AM
