Can a radius be added to a crank? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-14-2008, 09:30 AM
Just had an 1182 crank ground .010/.010, but the guy left VERY LITTLE radius on the journals. Can one be added, w/out grinding it down to .020/.020 or farther?
Old 11-14-2008, 09:54 AM
It could be done without a regrind, but you run the risk of ending up with too much rod side clearance as a result,because of having to go side to side to blend in to the cheeks of the journal, as opposed to grinding into the journals themselves to accomplish this!
Old 11-14-2008, 10:01 AM
NAIRB's Avatar
The radius has to be on his crankshaft grinding wheel. Normally you need to take a little bigger cut than just .010 to get a good radius on the crankshaft.
I've ground some .030 just to get a good filet on it.
Old 11-14-2008, 10:34 AM
Thank you very much!!!
Old 11-14-2008, 10:59 AM
The first answer is no, a new radius would have to be formed by reducing journal diameter.
However, there is another solution seldom used except by Chrysler. That is instead of a radius, the intersection point of the journal and cheek is pressure grooved. A small roller under high pressure is fed into this area to compress the metal into what's called a rolled fillet. This is, needless to say, a somewhat expensive process that can only be accomplished by a few pro race crank builders.
Bogie
267 crank into 350 block 74chevyflat Engine 6 08-26-2006 01:15 AM
Repairing a damaged crank by welding.. Old School Nut Engine 7 05-10-2006 08:05 AM
forged crank question Ratoflic Engine 2 04-18-2006 04:50 AM
crank problem Zartan Engine 17 05-11-2004 02:39 PM
400 Crank sb72elcamino350 Engine 3 04-15-2004 02:42 PM
