Absolutely YES. You need a pinion depth setting tool, micrometer or caliper to check shim packs and an inch pound torque wrench.
The installation kit runs 100 to 150 and you do not want to reuse bearings and crush sleeves. You will need to look for used gears. New ones start about 150 and up. Check out summit and jeg's for pricing. Jeg's brand gear sets come with good installation instructions. |
you do need some special tools, however you DON'T need a pinion depth tool.
You DO need: dial type inch lb torque wrench a hydraulic press bearing splitter big hammer big breaker bar big sockets regular foot lb torque wrench dial indicator micrometer here is one of the best writeups i have seen on the web, covers just about everything i learned(i have done at least 50 rear builds) http://www.pirate4x4.com/articles/te...sta/Gear_Setup Brendan |
Well I have or have access to all the tools. Thanks for that link _bang, I see that it is for a Dana 60, but I would guess the process and parts should be similar for a 10 bolt?
I was thinking of using this kit http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT with these gears(3.73) http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT And reusing my bearings and w/e else is left over, this needs to be done on a budget and in as little time as possible. After all the axle has never been opened up and it only has 50000 miles on it...ok? |
yea, mark the bearings and races if your reusing, just make sure they are good to go, and you might get yourself in trouble being on a budget and going "fast"
Just take your time and make sure everything goes back where it came from excactly, a common mistake is not marking the carrier bearing caps, make sure you mark them and put the back in the same orientation,(they aren't symetrical) And that GM 10 bolt is very similar to the Dana 60 Brendan |
| 10 bolt rear end on the street | black66 | Transmission - Rearend | 3 | 05-18-2006 10:52 PM |
| 10 Bolt Rear End | TORI1 | Transmission - Rearend | 1 | 12-29-2005 12:02 PM |
| F-body differentials, 9 bolt Borg Warner vs. GM 10 bolt | Mad Maggot | Transmission - Rearend | 8 | 02-17-2005 08:02 PM |
| Question about 12 bolt rear end | Roy_67_SS350 | Transmission - Rearend | 6 | 12-14-2003 11:57 AM |
| rear end gears | RHipps | Transmission - Rearend | 2 | 01-11-2003 11:29 PM |
