can the same power steering pump be used? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-02-2011, 11:30 AM
I am trying to figure out ideas on how or if I can run my same power steering pump. I have a 91 rs camaro 3.1 that has a 350 swap and I know there are brackets for a sbc ps pump but I cannot find one at a parts store, and have hesitated on going to a junk yard yet. Im trying to find the cheapest most reliable source.
I have been told I can get a ps pump from an old van with a 350 and it will bold directly through to the heads, but before I shell out money on a lost cause I wanted to get some other ideas out there. Thanks in advance!
Old 11-02-2011, 12:56 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Depends on what type of front accessory drive you're using: a long or short water pump or a serpentine set-up.
If you have the "standard" long w/p using V-belts, the p/s brackets can be bought from Summit, etc., or the best thing IMO is to go to the junk yard for it. Same thing for the serpentine set-up. Finding a complete short water pump set up in the 'yards these days might not be as easy. Long water pumps were used on small block passenger cars engines from 1969-'87 and on 1973-'86 light duty trucks. Before that they were short, after that they were serpentine.
Old 11-02-2011, 01:15 PM
Yes I forgot to mention that it is a long water pump so I am using v belts. And my concern about a junk yard is id assume there to be a lot more serpentine setups and then the setups may not match up exactly. Maybe I should just go up there and do some fishing around just to see what all they have cause it has been some years since my last visit
power steering pump for sbc with MustangII power rac TheCiscoKid Suspension - Brakes - Steering 5 12-29-2012 06:39 PM
hot power steering pump, steve t Suspension - Brakes - Steering 4 10-07-2008 06:36 PM
power steering pump as a secondary oil pump? lowROLLERchevy Engine 17 06-04-2007 04:02 PM
power steering pump baumholder19 Suspension - Brakes - Steering 2 04-09-2006 11:53 AM
power steering pump impala dreaming Suspension - Brakes - Steering 3 02-15-2003 06:00 PM
