Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - can see sand paper scratches in basecoat
Old 08-20-2013, 12:40 PM
cletus van damme's Avatar
cletus van damme cletus van damme is offline
I sanded down the whole fender with wet 600. I couldnt get the marks out, so I primed over the marks. Sanded the primer down with wet 600 again. Got the fender perfectly smooth.
I go to spray the base and same thing happens. I get scratches in the base coat. Now in different areas. One area that has the scratches visible was an area without sealer or primer on it. Some of the parts I primed came out fine, some were worse.
It seems random? The top of the fender came our perfect as usual...
Also, its metallic paint.
I am going to try to sand down the scratches again and then clear coat it. I am running out of paint and it doesnt have to be perfect; whole car needs to be redone.
Should I wet sand the scratches with wet 800 or 1200 before clear coat?
