can see sand paper scratches in basecoat - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 08-21-2013, 03:41 PM
Faith - Respect - Trust
It's good to know that we are on the same page, sometimes circumstances (customers) dictate that things need to be done a certain way that may not necessarily be the "By the book way" which would ensure the longevity of the job. I'm sure if you had your way, every job would have that solid substrate to apply a new finish over top. In cases such as the one we are dealing with it's so important to understand exactly what the OP is expecting in order to offer the information that best serves his needs.
LOL...I've actually been thinking of starting a thread entitled "what not to do when painting or doing body work on a car". I'm sure that the stories that would come out would be enlightening as well as humorous...I know from some of the things I've seen happen in body shops, there might be some shock value as well...LOL
Ray
  #32 (permalink)
Old 08-21-2013, 09:22 PM
Preacherman's Avatar
agreed! i say start the thread...laughter is better than medicine!
  #33 (permalink)
Old 08-21-2013, 09:30 PM
carolinacustoms's Avatar
Automotive Extraordinaire
Ray, you should start that thread. I have pictures of duct tape, spray foam, and roofin tin holding a 55 Chevy together. I could post for days lol.
Kelly
  #34 (permalink)
Old 08-21-2013, 09:59 PM
Kelly, I have one where a fellow used sweat socks, a hockey stick, and a Pepsi sign holding a rear quarter on a car...and that's not the worst one...LOL.
I'll start it in the early AM...I just hope it's fun and all meant in good spirit.
Ray
  #35 (permalink)
Old 08-21-2013, 10:11 PM
i bought a car once with news paper shoved in the rust holes with body filler on top
  #36 (permalink)
Old 08-29-2013, 12:56 PM
update.
I put the clear coat on today. I first sprayed a mist of base coat on again since its been a week since I put on base coat.
Used SELECTCLEAR™ 496-00™ - DuPont clear.
Came out real nice. I had some runs, and the scratches are visible, but you have to look real close to see them.
Ill have to take some pics tomorrow when it drys.
Thanks for the advice.
  #37 (permalink)
Old 08-29-2013, 02:26 PM
You waited a week before re-basing...refresh me...what kind of base was that again? Some base coats have 24 hour window of recoatability, some need to be lightly scuffed before they can be top coated, even with more base...and a light mist coat of base is a bit of a problem as well. In order for base coat to stick to itself after it has flashed and especially after sitting a week or more, it needs to go on medium wet so that the solvents can penetrate the existing base substrate...I don't want to be the bearer of bad news but you could have an adhesion issue...both the base you just applied sticking to the base and the clear sticking to the base.
I'm not saying you will, it could happen...in the future, be sure that you can top coat base coat after a week (some companies tech sheets say to remove the old base coat) and never a mist coat unless the base is still wet or flashing.
Ray
  #38 (permalink)
Old 08-29-2013, 04:13 PM
I just know its dupont base. It wasnt really a mist, just a quick spray after I scuffed it lightly with a scotch pad.
The owner of the garage went on vacation and I went to the cape for a week, so I couldnt finish it last week.
So far, it looks real good for my first paint job. Ill have to see what it looks like when its dry tomorrow.
  #39 (permalink)
Old 08-29-2013, 04:22 PM
That's great, the most important thing is that you gave it a scuff to open it up again so the solvents can penetrate the existing base coat...Please, pictures would be great.
Just trying to look out after you bud.
Ray
  #40 (permalink)
Old 08-30-2013, 10:38 AM
thanks.
I have about 4 drips/runs in the paint. Should I wet sand with 1500 to remove?
Also, I have some clear coat overspray on the quarter panel. I can scratch it off with my fingernail, but can I use 1500 sand paper to remove the over spray?
Finally, how long until I can wash the car? Its been 24 hours since clear coat.
  #41 (permalink)
Old 08-30-2013, 10:44 AM
A claybar will take the overspray right off, no sanding needed.
The Following User Says Thank You to Lizer For This Useful Post:
  #42 (permalink)
Old 08-30-2013, 10:51 AM
No, start with a coarser grit like 800 wet on a block, then move up to 1,000, then 1,500, 2,000 and finish with 2,500 then polish...as far as the over spray, try using a polishing compound...it should come off easily.
Give the car a few days...just to be on the safe side...I'm not familiar with the clear you used...it should be Okay to wash now but I'd hate to see water spots.
Hope this helps
Ray
  #43 (permalink)
Old 08-30-2013, 12:23 PM
I put alot of clear on, so the color shade is a little different, but barely recognizable.
Thanks, the over spray was coming off with just my fingers.
  #44 (permalink)
Old 08-30-2013, 12:34 PM
It actually looks quite good...I'm proud of you my friend. As time goes on, the color will come down a bit and be a closer match...I see the color difference between the header and and the fender...the header is quite faded and just a slight difference from the door to the quarter.
It's going to be an awesome driver, enjoy until it's time to do a complete, you've got a bit of experience now and if you have questions in the future, feel free to ask.
Ray
The Following User Says Thank You to 69 widetrack For This Useful Post:
Wet Sand paper and Dry Sand Paper taylorb2053 Body - Exterior 5 07-20-2011 12:57 PM
sand scratches on my 35 drchip Body - Exterior 6 12-17-2009 07:59 AM
backing for sand paper antiquecar Body - Exterior 1 07-12-2005 08:43 PM
DA sand paper $$$$ montea Body - Exterior 38 03-22-2005 11:52 AM
What sand paper should be stocked? GMW Body - Exterior 7 10-04-2003 08:32 PM
