can sohc 4.0 t chain noise go away - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-23-2012, 04:37 PM
I have been reading posts on the timing chain/tensioner problems & noises in the overhead cam 4.0 all pretty much the same input from all.Someone even posted the new style tensioner has more springs in it? (I measured old and new on a valve spring tester they both measured the same) Long crying short is there a permanent repair for ths ? Front and rear chains and tensioners later motor out twice.
Old 08-28-2012, 07:03 PM
the problem is with like most timeing chains thay streach over time and those motor,s where bad about it,, i worked at a salvage yard for few year,s we seen alot of that problem,, just need to replace them,,
Ford 4.0 SOHC chain noise Augusto Engine 8 08-23-2012 04:48 PM
427 Sohc roysaric Engine 8 08-23-2011 04:40 AM
Timing chain noise novadan Engine 19 01-26-2011 11:18 AM
Timing chain noise? V8 Kid Engine 2 06-10-2009 05:39 PM
4.6L DOHC SOHC Swap Wildcat66 Engine 1 04-15-2005 04:29 PM
