Can some one tell me who makes this pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-13-2013, 05:00 PM
just like tag says. got this off ebay. has a small leak. was hoping some one could tell me who makes it so i can get gasket
Old 04-13-2013, 08:01 PM
poncho62's Avatar
Wiki Edits: 5
Bigger pictures would help
Old 04-13-2013, 08:41 PM
maybe these will help.
ID:	73160   Click image for larger version
Old 04-13-2013, 08:52 PM
Banned
i still can not read the numbers. more info .any other marks spell them out,
Old 04-13-2013, 10:22 PM
There is nothing on it at all. the only thing on it is, in. I was hoping some would recognize it. it looks close to an aeromotive.
Old 04-14-2013, 05:49 AM
spinn's Avatar
It looks like the summit electric.
Here.pic.
Old 04-14-2013, 08:10 AM
Banned
get a sheet of gasket material and make your own, if you can not find the maker.
Old 04-14-2013, 09:56 AM
Did the quit selling it? All I see on there sight is the holly clone, with the summit name .
I have gotten it to stop leaking for now. The gasket that was leaking at the screws, was the one under the v shaped plate. That gasket actually drops into the pump as well, like it deflects fuel are something not sure.
Old 04-28-2013, 08:16 PM
ericnova72's Avatar
More for Less Racer
Threads a bit old, but more info... It is the Summit 150 GPH pump, now since discontinued.
Friend has two that work fine.
Appears to be a less glamorous copy of the Aeromotive pump to us, (without the fancy color anondizing on the aluminum and no chrome on the motor casing), you may want to contact them and see if their gasket is the same. They may even be the ones who made it for Summit to put there name on it.
This makes me so sad! Matt44 Hotrodders' Lounge 2 05-15-2011 08:52 AM
Who Makes The Best 2004r miles Transmission - Rearend 6 09-11-2009 01:54 AM
Need some help...who makes this???? Kevin45 Hotrodders' Lounge 7 04-05-2006 09:37 PM
Makes you wonder stu Hotrodders' Lounge 7 02-16-2005 08:39 PM
HV oil pump makes oil filter seal leak WBrianS Engine 13 11-20-2003 02:56 AM
