can someone help with engine id - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 01-11-2012, 12:13 PM
I have a 454 block with casting number 14015446. And I'm sure its a 6. It has a suffix code on front above the timing cover T1104AKS. I can't tell what this engine is. A 2 or 4 bolt, what year, or the actual horse power. I found a little plate glued to the side which says remanufactured for GM. It has a serial #71296 and a part #12339193
Recent Modern Electronic Engines posts with photos
350 Crate Engine: Loud humming sound after engine warms up sofa1515 Engine 2 01-11-2010 06:48 PM
Engine Help. Engine Turns over Hard, like siezed yet runs awsome. Merle9069 Engine 3 10-05-2008 06:38 PM
I need engine mount bracket ideas 1930 chevy with 302 boss engine. Riley Engine 3 07-25-2008 07:29 AM
say you have a THOUSAND horsepower engine..... (technical engine question inside) lowROLLERchevy Engine 14 02-24-2007 08:26 AM
the best engine parts, chain vs. gear, engine combos jollygiant_57 Engine 6 05-01-2002 09:34 AM
