What in the world have I come across here?
WIKI is a sham as facts are not usually researched prior to entry. Your misnomer of 400M reflects that. WIKI is the last place in the world I would look for fact or refer another to information. Quote:
And if you keep using this incorrect term, what other fallacies and wives tales are you still passing on? Quote:
Had you described it as a B BLOCK he would have understood you as he came here for info and got another wives tale instead. Quote:
I have not been here in quite a while as I do not enjoy mostly GM posts on a continual basis. What I find is another self-described expert giving out incorrect information. |
The balancers are different, but I have not come across a detailed explanation of the difference(s). If you are lucky, the VECI Decal will still be readable. Also, there should be stamped on the block a partial VIN of the donor vehicle. This will easily I.D. it. Otherwise, you are going to have to pull a head. The dowel trick is not concise because of the angle of the spark plug port on the 335 SERIES. Now see how easy that was? -DIFFERENTIATING THE 335 SERIES ENGINE FAMILY- -INTERNET MYTHS, LEGENDS AND MISNOMERS- |
Harmonic Balancer- OEM repl. All 400NO M. Casting I.D. No- D2AE-C Service PN- D2AZ-6316-C 73/74 74/76 W/O AC Casting I.D. No- D5AE 6316-DA Service PN- D5AZ 6316-B 75/76 A/C Harmonic Balancer- OEM repl. All 351M 75/ Casting I.D. Nos- D5AE-A/D5AE-AA/AB Service PN- D5AZ-6316-A W/O A/C Casting I.D. No- D5AE-CA Service PN- D5AZ 6316-B A/C Light Truck and BRONCO applications will most likely have a T as the third character in the Casting I.D. Prefix XXTX-XX The above info will give you an idea of how complicated the subject can get- |
BTW- The OP described the engine correctly. Either you are going to offer correct information or you are not. When you want to know something, do you want a bunch of wives tales or do you want facts? When you speak GHETTO MACHINE LANGUAGE, do you describe the CHEV 400 as a SBC or BBC? Why are the 348/409 referred to as W-SERIES? |
Just as "BBC" and "SBC", etc. has become part of the vernacular, so has "400M". It has NADA to do w/"correctness"- neither factory has used these terms "officially"- it has EVERYTHING to do w/RECOGNITION. Show me ONE guy who doesn't understand "400M" and I'll show you a tyro of epic proportion. Same as w/"SBC" or "BBC". EDIT- You badmouthed Wiki pretty good. I am a Crankshaft Coalition Wiki "editor"- and PROUDLY so. What of it? So are many members here- that's how good, reliable, peer-reviewed info becomes available for public use. And, I see YOU are also a wiki “editor”, albeit w/but one to your credit. Better than none, I suppose. LOL Last edited by cobalt327; 08-10-2010 at 11:51 AM. |
Name calling and personal attacks are against policy, a violation of the gudelines and will not be tolerated, period.
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association |
The ONE I edited was for safety not information. |
While this board may allow misinformation to be posted, I will surely call the contributor on it. If all that is going to be posted is misinformation then I surely have no business being here. Where is your policy regarding one's posting misinformation and then his/her/it's/mutants continuing ignorance when called on it? |
I can identify all the 351M/400/400M. Scrap Iron. $.07/pound. Take your pick.
When I got out of the stock engine building business 10 years ago, I could not give one of those engines away. At the time, scrap was cheap and had to pay someone to haul them off, at least 50 of them. |
I think I read somewhere though, that someone did real good in that "Engine Masters" deal w/one of them, I believe it was the 400M. |
This thread doesn't appear to have any new technical merit, has deterriorated, and is being locked.
