-   -   Can someone tell me how to decode this T-400 tag? (http://www.hotrodders.com/forum/can-someone-tell-me-how-decode-t-400-tag-228807.html)
adam83 01-24-2013 09:44 PM
Got this off my 79 3/4 ton. it reads C 754 H, 79-CH-30242
http://i203.photobucket.com/albums/a...0/P1000417.jpg
mmerlinn 01-24-2013 11:14 PM
Not much there except for the date and the serial number. All it tells me is that it was built for a 79 chevrolet of some sort.
dub 01-24-2013 11:22 PM
Try This site....
Chevrolet Rear End Codes
adam83 01-25-2013 09:29 PM
Thanks for the help. The numbers across the bottom are the seriel number or partial vin correct? If so, they dont match the truck's vin.. So now Im most interested in what the '754' stamped in the middle of the tag means. any ideas?
dub 01-25-2013 10:06 PM
Sorry,
Mis-understood the original question.
This site will tell you everything you need to know about it.
http://www.novaresource.org/trans.htm
mmerlinn 01-26-2013 08:19 PM
Bottom number are a SERIAL number for the transmission and have no correlation to VIN nor any other information.
dogwater 01-29-2013 07:03 AM
I had one of those tags on my 700r4 and I couldn't fine any info. But all the autos I've seen with those tags are really clean inside an in good shape.
SSedan64 02-15-2013 09:52 PM
Another >> http://www.teufert.net/trans/t-400.htm
adam83 02-16-2013 12:51 AM
Thank you, that was extremely helpful
