Can someone tell me how to decode this T-400 tag? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-24-2013, 09:44 PM
adam83's Avatar
Got this off my 79 3/4 ton. it reads C 754 H, 79-CH-30242
Old 01-24-2013, 11:14 PM
Wiki Edits: 85
Not much there except for the date and the serial number. All it tells me is that it was built for a 79 chevrolet of some sort.
The Following User Says Thank You to mmerlinn For This Useful Post:
adam83 (01-25-2013)
Old 01-24-2013, 11:22 PM
dub's Avatar
dub dub is offline
Last journal entry: Time to drive..
Try This site....
Chevrolet Rear End Codes
Old 01-25-2013, 09:29 PM
adam83's Avatar
Thanks for the help. The numbers across the bottom are the seriel number or partial vin correct? If so, they dont match the truck's vin.. So now Im most interested in what the '754' stamped in the middle of the tag means. any ideas?
Old 01-25-2013, 10:06 PM
dub's Avatar
dub dub is offline
Sorry,
Mis-understood the original question.
This site will tell you everything you need to know about it.
http://www.novaresource.org/trans.htm
Old 01-26-2013, 08:19 PM
Wiki Edits: 85
Bottom number are a SERIAL number for the transmission and have no correlation to VIN nor any other information.
Old 01-29-2013, 07:03 AM
78 Z28 Camaro
Last journal entry: 700r4 still running strong
I had one of those tags on my 700r4 and I couldn't fine any info. But all the autos I've seen with those tags are really clean inside an in good shape.
Old 02-15-2013, 09:52 PM
SSedan64's Avatar
Another >> http://www.teufert.net/trans/t-400.htm
Old 02-16-2013, 12:51 AM
adam83's Avatar
Thank you, that was extremely helpful
Where to decode this trim tag? K and K Hotrodding Basics 0 08-09-2010 10:44 PM
T-400 tag decode? Fang16 Transmission - Rearend 3 04-01-2010 09:00 AM
Trim tag decode miller350ss Body - Exterior 1 10-10-2008 12:42 PM
decode rear end tag ford 9inch cswinc1028 Transmission - Rearend 1 05-13-2008 07:02 PM
Ford Rear tag decode 87442lover Transmission - Rearend 1 05-14-2004 10:15 AM
