Can someone tell me the steps to replacing seals on Rotary SP088 lift - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-13-2010, 03:51 PM
I have a old Rotary 2 post lift that is leaking real bad out of one of the hydraulic cylinder rod seals.I have the rebuild kits in my hand but do not know where to start.I have built a few cylinders on my farm equiptment before.How do i get long skinny cylinder out to take it apart or do you build it in place?
Old 08-13-2010, 09:25 PM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
I did one on our Ammco lift about a year ago. I took the ram out, screwed the end off, pulled the piston out, resealed the piston and the wiper and seal in the cap and reassembled it, pretty easy actually,
Replacing Turbo 400 front seals Dan B Transmission - Rearend 2 05-15-2006 03:46 AM
Replacing valve seals 35olds Engine 3 02-11-2006 01:05 PM
what are the steps to replacing a heads gasket andrewpruitt Engine 6 03-19-2005 06:06 PM
Replacing rear seals on a 700r4 Jag Daddy Transmission - Rearend 1 05-27-2003 02:45 AM
Replacing rear axle seals 40fordhotrod Transmission - Rearend 4 03-25-2003 06:02 PM
